Hello Vinzent
Currently, this evaluation is unfortunately not yet directly possible in RFEM 6
In RFEM 6, the inserted reinforcements cannot currently be output as a piece or quantity list (e.g., total steel quantity in tons). The issue is known in development, and the request has already been accordingly added
Workaround:
One possible approximation is to represent the reinforcement via a structural modification and consider it in a separate load case (Image 1).
Then you can compare the self-weight in the Z-direction:
Load case "Self-weight concrete without reinforcement"
vs. load case "Self-weight reinforced concrete"
From the difference, the additional mass (and thus approximately the steel quantity) can be derived.
The following post is dedicated to comparing models:
https://community.dlubal.com/t/wie-vergleicht-man-effizient-modelle/1911
Eike Hartmann
Image 1:
