⚡ Computational Fluid Dynamics (CFD)
:white_check_mark: regular updates with practical, easy-to-follow articles
:white_check_mark: written by Dlubal specialists
:white_check_mark: including graphics and step-by-step explanations
Our latest articles take you into the world of advanced wind simulation – from roller coaster wind interaction to new turbulence models:
:wind_face: Transient Simulation Using Time-Varying Inlet Boundary Condition in RWIND
Read More
Time Varying Inlet Boundary Conditions (TVIBC) introduce realistic turbulence fluctuations into wind simulations, improving accuracy over steady inflows. This approach enhances predictions of peak pressures, dynamic responses, and gust effects on structures. TVIBC bridges computational results with wind tunnel data and modern design codes, making it more accurate tool for structural wind engineering.
:wind_face: Wind-Structure Interaction in Roller Coaster Design
Read More
Roller coasters are among the most iconic examples of engineering artistry, combining structural innovation with human excitement. Yet, behind the adrenaline rush lies a sophisticated design process that ensures safety, reliability, and comfort. One of the most critical factors in roller coaster engineering is wind-structure interaction.
:wind_face: Advantages of CFD Wind Simulation Over Code-Based Static Wind Load Calculations
Read More
The article highlights how CFD wind simulation surpasses traditional code-based calculations by accurately modeling complex geometries, providing detailed pressure distributions, and capturing local wind effects. It emphasizes the flexibility of CFD in wind direction and site-specific profiles, as well as its integration with structural analysis. Despite higher computational demands, CFD offers greater precision and efficiency, making it especially valuable for tall, irregular, or wind-sensitive structures.
:wind_face: New Turbulence Model in RWIND: WALE (LES)
Read More
The article introduces the WALE (LES) turbulence model as an advanced subgrid-scale model within the Large Eddy Simulation framework for CFD simulation. Unlike conventional RANS approaches, which average turbulence effects, WALE resolves the large energy-carrying eddies while modeling only the smaller scales, thereby enabling a highly detailed and transient representation of turbulent flow structures.
Curious about practical applications? Check out these customer projects:
:wind_face: Bluebonnet artwork in Dallas, USA
:wind_face: Czech Pavilion EXPO 2025 in Osaka, Japan
:wind_face: Steel Membrane Roofing at Xuzhou University of Technology, China
:wind_face: Residential Buildings in Trieste, Italy
Have a look and share your thoughts!
There's more to explore :slight_smile:
Our newest articles cover ventilation workflows, rooftop wind simulation, and wind effects on timber structures.
:wind_face: CFD-Based Ventilation Diagram Using Rhino, RWIND, and Snagit
Read More
The article describes a simple workflow for creating ventilation diagrams by modeling in Rhino, running airflow simulations in RWIND, and enhancing the results in Snagit. This process produces accurate and visually appealing diagrams that show how air moves around buildings, making them ideal for architectural analysis and presentations.
:wind_face: Critical Role of Wind Simulation for Rooftop Equipment
Read More
Rooftop installations like HVAC units, solar panels, and antennas are highly exposed to wind loads. This article explains how CFD-based wind simulation provides deeper insight into local wind effects, enabling safer and more efficient rooftop designs. By visualizing real airflow behavior, engineers can prevent uplift failures, optimize anchoring systems, and ensure long-term structural reliability beyond standard code assumptions.
:wind_face: Wind Simulation on Timber Structures
Read More
The article explains how wind loads affect timber structures, highlighting their sensitivity to dynamic wind effects due to low weight and flexibility. It outlines the main wind components, design strategies, and relevant Eurocode standards. Both code-based methods and CFD simulations are discussed.
There's a new article introducing a method to generate random, spatially correlated wind profiles for time-resolved CFD simulations.
:wind_face: Random and Spatially Correlated Wind Profile Generation
Read More
The approach is based on atmospheric boundary-layer theory and generates a physically consistent turbulent inflow on a vertical inlet plane by combining a prescribed mean wind profile with stochastic velocity fluctuations.
Our latest article explores the impact of boundary layer and inflow modeling on CFD accuracy, including near-wall flow, transient forces, and simulation fidelity.
:wind_face: Impact of Boundary Layer Modeling on CFD Simulations
Read More
This article discusses the effects of wall function modeling on aerodynamic CFD simulations in RWIND, focusing on how high-y+ approaches improve computational efficiency but reduce accuracy in near-wall flow prediction, boundary layer behavior, and flow separation. It highlights the trade-off between simulation speed and aerodynamic fidelity and explains when wall functions are appropriate for engineering applications.
How do wind effects translate into realistic pressure distributions on structures? :thinking:
Learn about the impact of surrounding structures, shielding effects, pressure coefficients, and peak suction pressures.
:wind_face: Effect of Surrounding Structures on Tensile Membrane Structures
Read More
The aerodynamic performance of tensile membrane structures is highly dependent on their surrounding environment. Unlike isolated structures, membrane canopies located within urban areas or densely built environments are exposed to complex flow patterns generated by neighboring buildings and obstacles.
These surrounding structures can significantly alter the local wind field, resulting in substantial changes in wind pressures, aerodynamic forces, and structural deformations.
:wind_face: Calculation of Pressure Coefficients Using Time-Domain Extreme Value Analysis
Read More
Wind-induced pressure coefficients are fundamental parameters in the design of building envelopes, roof cladding systems, and structural components. Traditional wind standards provide tabulated values for local (cp,1) and structural (cp,10) pressure coefficients, which are generally derived from wind tunnel measurements and statistical processing.
Modern computational techniques allow these coefficients to be estimated directly from pressure time histories obtained from measurements, CFD simulations, or synthetic turbulence generation.
