I have noticed an error in RSTAB 8 in the EC 3 add-on module.
RSTAB 8 (Version 8.38.01)
In the verification in EC 3 (stability verification bending and compression according to 6.3.3 method 2), the given formula for the verification is correct, but when I insert the values determined by RSTAB itself into the formula, I get 0.96 instead of 0.92 as the maximum utilization
Nz + My
0.10 + 0.86 = 0.96 and not 0.92
I have attached the file as Test 1 so that you can better understand it.
I have checked the file and the calculation. You’re right, the result has to be 0,96 if you enter the given values. I will check that with our development department.
I just wanted to quickly ask how things are going with the problem. Since there is no current version of RSTAB 8 available, I assume it is still being worked on, right?
