Import DXF File into RSECTION
Dear
We have issues importing dxf files into Rsection 1.15.004.
After we prepared the file in dxf of the selected profiles, after import to Rsection we get the below message
We checked (after consulting online suggestions from Dlubal site and MIA):
  • Units are mm
  • Dimensions are ok with the supplier prescriptions, so not too big
  • Profile is close to 0 UCS system
In the past we didn't have this issue
What might cause this issue? Can you please advise where we should look into ?
thanks
Bogdan
Schuco_M 536180_484010.dxf (182.9 KO)
Schuco_M 322260.dxf (161.0 KO)
I am getting the same error message when I try to export results from RFEM6 (v15.0004).
Hi BogdanLazar,
The background technology for DXF Import was adjusted in version X.15.0004.
I could not open your DXF file in AutoCAD 2025 and Rhino 8 also detected some errors inside your file.
It is working with version X.14.0013.
It seems like we have stricter error tolerances for some DXF files due to the new DXF technology. I forwarded this problem to our development team and will let you know once we have a solution for this issue.
Paul Sivolgin
