regular updates with practical, easy-to-follow articles
written by Dlubal specialists
including graphics and step-by-step explanations
The following series of articles highlights key aspects of lateral-torsional buckling in timber structures – from theoretical principles to practical application.
Read More
Slender bending beams that have a large height-to-width ratio and are loaded parallel to the minor axis tend to have stability issues. This is due to the deflection of the compression chord.
Read More
The first article of the series explains the theoretical background for the analytical determination of the critical bending moment Mcrit or the critical bending stress σcrit for the lateral buckling of a bending beam.
This article uses examples to verify the analytical solution with the result from the eigenvalue analysis.
Read More
The practical application for determining the critical bending moment or the critical bending stress is demonstrated in the second part of the series.
In this article, the critical bending moment is determined by considering an elastic foundation resulting from a stiffening bracing.
Curious about practical applications? Check out these customer projects:
Community Center in Qingdao, China
Faculty Building of the University of Navarra in Pamplona, Spain
Sprint Canopy, Singapore
Have a look and share your thoughts!
