Mesh refinement
I'm finding it hard to mesh my model with different size without distortion, can I manually change the coordinate position of my mesh node in rfem-5
Hi Chukwudalu,
welcome to our Dlubal Community :waving_hand: We are very glad to have you here!
Generally: Lines that are integrated into surfaces create a constraint for the meshing algorithm. Hence, it may help to add some additional lines into the surface.
Specifically: If you have a specific issue with a model, please share it (without results) so I can take a closer look.
In RFEM 5 it is not possible to adjust the mesh coordinates manually.
To be able to answer with pictures you have to click on reply instead of add comment:
