I would be glad if the cube in the top corner of the "Edit Steel Connection" window also adjusts when I activate a different coordinate system.
Additionally, it would be practical if, after right-clicking on the cube, I could quickly set a custom view as the default view, similar to Inventor. I know this is possible via the camera in the navigator, but sometimes this function would be more intuitive.
I hope I was able to clearly convey my concern.
Regards
Maik Klimusch
Hello @Maik0501,
I have noted the first request - thank you very much for that. It will be processed according to the priorities in development.
Do you see such a big advantage in implementing it in Inventor? After all, it is just one click with the camera icon.
Fabian
I actually don't see an advantage for the second point.
Maybe it's just a matter of getting used to it because I work with both systems in parallel.
It probably bothered me mainly because I didn't have a fixed point in the editing window of the connections where I could align my cube.
