Displaying result histories on cross-section through volume
Hello dear community.
I am a student and am currently learning how to use RFEM 6.
I want to display stress distributions of a clamped solid body.
Here's what I have already done:
  • Defined material
  • Created solid body
  • Applied loads
  • Clamped the body
  • Calculated :white_check_mark:
However, when I want to look at the result distributions of the section, I have the problem that none of the stresses in the section are displayed. Everywhere it just says: "Not defined."
How do I fix this problem?
Here are 2 more screenshots of the problem
Hi V8Racer,
The display of the "result progressions for selected result cuts" is unfortunately not yet available. The evaluation of the results is possible in the result navigator.
I have informed the program developers / programmers accordingly. I cannot reliably predict when the change will be implemented in the program.
You can follow new product features, updates, update reports, bugs, and features here:
https://www.dlubal.com/de/support-und-schulungen/support/faq/005149
You can display the results for the volume body on the boundary surfaces including all values:
Marco Nikoleizig
