I am a student at HTW Berlin. I'm interested in using the Geo-Zone Tool API for a project I currently have. But I don't think I have access to the API because I keep getting an invalid credentials error. My ID is 326907. Thank you in advance.
Hi rakursadi,
first of all, welcome to the community ![]()
Regarding the usage of the GeoZoneTool as a student, this is normally not supported from our side, because we don't see a use case for it. If you'd like, you can tell me more about your use case so I can better understand your needs.
Hello Robert,
I wanted to use the API to get the wind and snow load zones automatically when i input a location.
Thanks
Hi rakursadi,
I guess you don't need to do it several times, or am I wrong? You can use i for your current project via the UI, this should give you the right values.
Hello Robert,
For this particular student project, i was given a building with varying roof pitches at different locations to see how the roof construction and the structural requirements would change. Manually looking up the wind and snow loads on each location would be quite tedious, using an API will help me automate this.
Thanks in advance
Hi rakursadi,
How long would you need access to the GZT for?
Hi Robert,
I reckon 2 weeks would be enough
Hi rakursadi,
Unfortunately, we can’t unlock a time period here; instead, I’ve given you 200 requests. This should be enough i guess.
I hope this helps.
