Attribute value in component is not being output
Servus,
with API II I noticed the following small bug:
The value of the attribute member_selected_sides in the component TYPE_MEMBER_EDITOR is not output via API II. The corresponding value field is not present in the SteelJoint object.
is_active: true
type: TYPE_MEMBER_EDITOR
name: "Member editor 1"
settings {
  rows {
    key: "member_selected_sides"
Of course, I have attached an exemplary model and script to reproduce the issue.
20260604_Bug_Report_Member_Editor_Missing_Value.rf6 (1.2 MB)
from typing import cast
from dlubal.api import rfem
from dlubal.api.rfem.steel_joints_objects import SteelJoint
def main() -> None:
        joint = cast(typ=SteelJoint, val=rfem_app.get_object(obj=SteelJoint(no=1)))
        print(joint.components.rows[12])
if __name__ == "__main__":
    main()
Hey Benedikt,
thanks for the detailed documentation! :slight_smile:
I was able to reproduce the error and have forwarded it to the developers for fixing.
Rebecca Göbel
