Calculating multiple models one after another
I’m using RFEM 6 for my master’s thesis and investigating several variants of HBV models. I’d therefore like to automatically run calculations for multiple open models one after another, rather than starting the calculation manually for each model. Is there a way to do this?
Thank you in advance.
Hello @adrian.mayer,
Multiple models cannot be calculated simultaneously in the RFEM user interface. However, you could open another instance of RFEM on the same computer and calculate another model there at the same time.
To start the calculations automatically one after another, using the Dlubal API is a good option. The script could start the calculation of each model in sequence.
You can find more information about the Dlubal API at the following link:
Rebecca Göbel
