Consideration of creep deformation
For my thesis, I want to calculate a timber roof structure using RSTAB 8. In the deformation analysis, I would like to compare the effect of creep deformation with the initial deformations. Online, I can only find information stating that creep deformations are automatically taken into account using the relevant material properties and service classes of the structure. However, I can only find a single deformation value at the end of my design calculation. I therefore cannot determine the initial, creep, and final deformations that occur in the system.
In an FAQ, I found a setting where you can enter kdef separately. However, I assume this was done in RFEM (see Figure 1). Is it possible to account for creep in timber structures in RSTAB 8 and, if so, to display the corresponding kdef factor or the creep deformation?
