Sheet editor => rectangular opening with rounded corners
Dear Dlubal Team,
As I am currently doing an FE comparison calculation for a connection, I wish it could be modeled more efficiently. For the connection, which can initially be modeled very quickly based on the component type "end plate joint," I would like to subsequently insert a rectangular opening with rounded corners into the respective end plates. Unfortunately, it is currently not possible to round the corners of the rectangular opening; a corresponding feature would be great!
Here is the desired geometry:
Best regards, Nick
Hello @DeflectionPerfection,
I have documented your request.
For the moment, you can achieve this (somewhat awkwardly) through 6 rod openings:
If you need such shapes more often, you can also save the components as a template.
Fabian
