šŸ“„ Column Base with Anchorage
The model shows the detailed structure of a column base with an anchorage, a critical component in many structures. It illustrates how the column base is securely anchored in the foundation to effectively transfer vertical loads and ensure stability. This solution is specially designed for structures that place high safety demands on the anchorages.
Preview 3D Model
Information
Very helpful, thank you
