Contact Stresses between two surfaces
Is there a way to display and evaluate the contact stress between two surfaces between which a surface contact is defined?
Hi dolezaltom,
thank you for your question!
At the moment, no results are available for surface contacts. We're actively working on improving this functionality. :construction:
In the meantime, as a workaround, you can define a contact solid between the two surfaces and evaluate the resulting stresses this way. This method can help you proceed with your analysis until the feature is fully available.
Let us know if you need any assistance setting this up — we're happy to help!
Hi Stefan, is there an ETA on this feature?
Kind Regards
The feature is currently in the final stages of development. If testing goes smoothly, we expect to release it within the next few weeks.
