Variable load copy on bar assembly
When copying rows from the load table for loading on member sets, the variable-load rows are copied, but without the load parameters (parameter table), even though those can be copied and pasted afterward without any problem.
This is particularly problematic when cutting and pasting, since the source to copy from is then no longer available.
It would also be useful to have a function for moving or copying a load from one case to another.
What is strange is that graphical copying works perfectly, but copying rows in the table does not.
