For my MEng thesis, I am analyzing localized models of a flat slab. My aim with these models are to assess the deflection and rotation of the slab under creep and shrinkage. However, each time I run my analysis, i get a failure/error message which says the load combination could not be calculated/executed.
- I have selected the correct analysis type in the Load Combinations dialogue box i.e. Static Analysis (Creep and Shrinkage|Linear)
- I have ticked/selected Creep & Shrinkage in the material and cross section/thickness dialogue boxes.
- I have also enabled non-linear material behavior and time-dependent analysis in the model Base Data.
Previously I created a different slab column local model where i selected the exact same settings, and the creep and shrinkage load combinations seem to calculate in that model but not the current one i am assessing. Could you please advise on how to rectify this error. The model is attached below.
MEng Thesis-Parkade- Column C133-C25-C53.rf6 (1.3 MB)
Hi AzharHoosain,
Thank you for your inquiry.
If you want to account for creep and shrinkage in the ULS under the sustained load from the quasi-permanent combinations, you need to take the following steps.
Turn off the Combination Wizard. (Image 1)
Set the load cases to 'Static Analysis' (Image 2).
You can then select the combination as desired (Image 3).
Alternatively, you can select only permanent load cases directly in the combination. Please see the following image.
Bastian Kuhn
Hi Bastian,
Thank you for your reply. I tried the above mentioned, however, that still does not seem to resolve the issue. For some reason, the analysis is unable to run and I end up with an error as shown below.
I noticed that if i de-select "shrinkage" in the time dependent properties dialogue box (leaving only "Creep" selected) then the analysis runs. With both "Creep" and "Shrinkage" selected, the analysis fails.
Regards,
Azhar Hoosain
Hi AzharHoosain,
hm that`s strange. Could you please update the programm to the current version 6.15?
Which Option did you choose first or second I described in my previous post?
If it still doesn`t work please send me updated model.
Best Regards
Bastian Kuhn
