🏗️ Customer Projects: Engineering in Practice 04/2026
Our software helps engineers across the globe to design innovative and reliable solutions for challenging constructions. Take a closer look :eyes:
5 Outstanding Projects powered by Dlubal Software
Tennis Hall in Fürth, Germany
The project involves a new building of a hall over an existing tennis court. The glued-laminated timber hall has a span of 18 m (59 ft) and was built on micro screw piles.
EV Charging Station, Sweden
XYZ Engineering & Consultancy has developed a standardized roof structure for EV charging stations. The modular design was developed using RFEM to ensure load capacity.
Summit Park Pavilion in Ohio, USA
Novum Structures LLC was commissioned to design and construct this roof canopy. The structure was designed using Dlubal Software to achieve the 128-foot span of the double-layer HSS girders.
Experiment Field Shielding in Munich, Germany
Radiation shielding enclosure for a three-axis spectrometer constructed in the West Neutron Guide Hall at the Heinz Maier-Leibnitz Research Neutron Source (FRM II). The goal was to cover the entire experimental field and thus effectively reduce radiation emissions. To this end, a steel substructure was designed and covered with lead sheathing.
Roof Structure in Würzburg, Germany
Being part of a redevelopment, a wooden tower structure was repaired, renovated, and functionally reconstructed. The aim of the project is to adapt the structural and technical infrastructure to current requirement.
Discover more real-world projects on our website and let us know how we can support your next project :fire:
