Display of loads in the printout when adjusting load cases
Is there a way to automatically update the load display in an existing batch print when the load case/loads change?
In my case, I created a structural model and used the batch print to display the loads in the printout:
The nodal loads on the visible nodes should be displayed under Loads for all selected load cases:
This works when first setting up and using the feature. The problem is that the loads were changed afterward: via the API, the same load cases were created again with updated loads (but on the same nodes), and now none of the loads are visible in the batch prints.
Is there a way to make these loads visible in the existing batch print?
Ideally, I’d like an adjustment that means I don’t have to recreate the printout each time, but instead the batch print updates to show the “new” loads on the nodes displayed in it.
Nick Böttcher
