Divide a line with varying distribution line load
Hello :waving_hand:
I encountered unexpected program behavior when dividing a line to which a line load with a Varying distribution type is applied.
When dividing such a line using the Connect ... function, the variable load is not “distributed” onto the new lines according to its actual distribution; instead the exact original load is applied to all resulting lines.
This seems non-intuitive (and also very problematic), so I checked the behavior when using the Divide Line tool. This gives a different and expected result.
I also checked RFEM 5, and there it produces the expected result in both approaches.
The above seems like a bug in RFEM 6 (and, to be honest, a step backward compared to RFEM 5).
Can someone confirm that this is not intended behavior in RFEM 6 and that it should be fixed?
Hi r.sajdak,
Thanks for bringing this up! :blush:
Both functions you mentioned serve the same purpose, but the “Connect Lines/ Members” command behaves a bit differently. This is intentional and controlled by a specific setting:
https://www.dlubal.com/en/downloads-and-information/documents/online-manuals/rfem-6/003180
What you can do
  • You can disable this behavior in the Program Options.
  • Once disabled, both functions will react exactly as you expect.
So just to be clear:
:backhand_index_pointing_right: This is not a bug, but designed behavior that can be adjusted as explained.
If you need help finding the option or have further questions, feel free to ask :+1:
Thank you for your answer :folded_hands:
I was not aware of this. This is a direct solution to my problem. :slight_smile:
Additionally I now wonder what else this setting “Copy properties to created lines/members” controls.
From what I’ve checked so far, if I have assigned comments or support and line/member parameters (such as hinges, reinforcement, etc.), they all remain on the created lines.
So what is not copied to the new lines when I use the “Connect” tool? :thinking:
Hi r.sajdak,
We don’t have a complete list of all objects affected by this option. However, based on our internal checks, the following objects use different split logic depending on the selected setting:
  • Member Transverse Weld
  • Member Local Section Reduction
  • Effective Lengths
    • These are either copied or moved – they are not split
  • Boundary Conditions
    • Same behavior as Effective Lengths
  • Concrete Reinforcement
  • Member Imperfection
  • Loads
  • Member Result Intermediate Points
  • Member Section Distribution
  • Member Eccentricities
  • Member End Slope
  • and more
I hope this overview helps you better understand the behavior :+1:
If you need details on a specific object or scenario, feel free to ask!
