Result Smoothing: Stress-Strain Calculation via API
Since I am unable to access results determined by the result smoothing "constant in mesh elements" via the static analysis API, I am now trying this using the Stress-Strain Calculation addon.
Here you can define in the global addon settings which result smoothing settings should be used for the addon, which I set to "constant in mesh elements" according to the nonlinear material:
dlubal_example.rf6 (1.0 MB)
My initial hope was with the following API code:
from dlubal.api import RFEM
from dlubal.api import common
from openpyxl import load_workbook
import math
import pandas
Settings
API_KEY = "non of your business"
Select a free load case number in the model
lc_start = 1007
co_start = 1
def show_Weld_stresses(RFEM_app, lc_no):
results: common.Table  = rfem_app.get_results(
       results_type=rfem.results.ResultsType.STATIC_ANALYSIS_SURFACES_BASIC_STRESSES_MESH_NODES,
    ).data
results_lc = results[
    (results["loading"] == f"CO{lc_no}") #
    #(results["element_no"].isin([6885])) &
    #(results["tag"] == f"middle")
#cols = [
#    "loading",
#    "surface_no",
#    "mesh_node_no",
#    "element_no",
#    "sigma_x",
#    "sigma_y",
#    "tau_xy",
#    "tau_xz",
#    "tau_yz"
#print("\nResults:\n", results_lc[cols].to_string())
results_analysis: common.Table = rfem_app.get_results(
       results_type=rfem.results.ResultsType.STRESS_STRAIN_ANALYSIS_SURFACES_STRAINS_BY_SURFACE,
).data
#results_lc_analysis = results_analysis[
#    (results_analysis["loading"] == f"CO{lc_no}") &
#    (results_analysis["element_no"].isin([6885]))
#print("\nResults:\n", results_lc_analysis)
print("\nResults:\n", results_analysis)
def rechne_kombination(RFEM_app):
    rfem_app.calculate_all(
            skip_warnings=True
def main():
lc_counter = co_start
with rfem.Application(api_key_value=API_KEY) as rfem_app:
    info = rfem_app.get_application_info()
    print(f'Version: {info.name}')
    rfem_app.get_active_model()     #loads the manual opened model into the here written script
    while lc_counter < 3:
         rechne_kombination(rfem_app=rfem_app)
         show_Weld_stresses(rfem_app=rfem_app,lc_no=lc_counter)
         lc_counter += 1
if name == "main":
main()
To obtain the strains according to the result smoothing "constant in mesh elements".
Because these were manually set in the opened model beforehand via GUI in the global addon settings.
If I now run the above code, I get the following results:
If I check whether these actually correspond to the constant smoothing, unfortunately it does not seem to be the case, if I am not mistaken, because let's look at the first row of the results:
For element 5 in load combination 1, at the bottom layer, I would need a comparison strain according to Mises of 0.000626 (0.626 per mille).
Unfortunately, it looks like that graphically for the constant mesh smoothing a result of 0.61 per mille occurs at element 5:
The tabular output of the static analysis results of the comparison strain according to Mises of load combination 1 also corresponds to these 0.61:
If, on the other hand, I set the result smoothing for static analysis to continuous in surface sets or in surfaces, I get a comparison strain of 0.63 per mille, which matches those of the Stress-Strain results addon => although it is explicitly set in the Global Settings to use the smoothing constant in mesh elements.
Here are the results of the static analysis for the calculation settings: continuous in surface sets or in surfaces:
It therefore seems that the Stress-Strain Calculation addon itself, even with global settings to other result smoothing within the API, always outputs the results based on the setting continuous in surface sets or in surfaces.
Therefore the questions:
  1. Am I correct with my statements/assumptions here? Or am I making a mistake?
  2. Is it possible to explicitly define the global settings of the Stress-Strain Calculation addon within the API instead of first in the GUI? And if yes, how?
Hi DeflectionPerfection,
can you send the py file for that? Thanks.
Thank you for the feedback,
The file is attached,
to make it work for you, of course, the API key must be adjusted; I have stored it as a string variable in line 11 of the code (as seen in Visual Studio Code) :blush:
konstanteNetzglättung_schweißtester copy.py (2.1 KB)
I would be very pleased to receive a response.
Nick Böttcher
Thank you very much for the example. I have taken a closer look at the matter.
Regarding question 1:
The table provided by the API did not take the smoothing into account. I have forwarded this accordingly to the developers.
Regarding question 2:
You can access the global settings for the stress-strain calculation as follows (one setting as an example):
from dlubal.api import RFEM, common
from google.protobuf.json_format import MessageToJson
with RFEM.Application(port=9000) as RFEM_app:
# Get global settings tree table for Stress Analysis add-on (active model)
design_settings_tree: RFEM.GlobalSettingsTreeTable = RFEM_app.get_design_settings(
addon=RFEM.DesignAddons.STRESS_ANALYSIS
print(f"stress_strain_analysis_global_settings_tree_table")
print(f"RFEM.DesignAddons.STRESS_ANALYSIS:\n{MessageToJson(design_settings_tree)}")
# breakpoint()
key='calculate_surfaces_stress_in'
common.set_values_by_key(
    tree=design_settings_tree,
    key=key,
    values=[1]  # 0: in mesh node, 1: in grid point
# Set specific value from the global settings
rfem_app.set_design_settings(
    addon=rfem.DesignAddons.STRESS_ANALYSIS,
    global_settings_tree_table=design_settings_tree
How to access the corresponding settings is demonstrated in a similar manner in Webinar | Concrete Design with the Dlubal API using the example of concrete design.
Thank you very much for the response.
The webinar and the sample code are really excellent and will definitely help me further in the future!
Unfortunately, it does not solve my current problem, because even when constants are explicitly set in network elements within the code, access to the correspondingly smoothed results is still not granted.
Best regards, Nick
