Hi, I’m importing an omega-shaped DXF. I use the “Create elements automatically” option and enter the thickness. At some point, an error appears that I can’t read—something blocks the reading. Then it continues and creates points, lines, elements, and parts, but nothing is visible.
Hello @Diegocp and welcome to Dlubal Community
Here are few things you can check:
1. Length units of the DXF
When elements, parts and points are created but nothing shows up, the cross-section is often just at the wrong scale. For example, a drawing in mm gets read as m, so the section ends up huge or tiny. In the import dialog, you can pick the unit in the list “Length units of DXF template” so it doesn’t come from the DXF file. After importing, also try “Show all” (zoom to fit) to check whether the section is just outside the view.
2. “Max. thickness” with automatic element creation
With “Create elements automatically”, the value you enter isn’t the wall thickness. It’s the maximum thickness. RSECTION looks for center lines between parallel contour lines and creates elements only where the distance is within this value. Set it a bit larger than the thickest wall of your omega section.
(If your DXF has center lines rather than contours, use “Lines as element center lines” and enter the real thickness in “t”.)
3. Two-step alternative
You can also import the DXF as a template first (lines only) and check the geometry. Then create the elements afterwards with Edit → Manipulation → Create elements automatically.
If it still doesn’t work, could you send us the DXF file and a screenshot of the error message? Then we can check it directly.
More information:
- Manual – DXF import in RSECTION: https://www.dlubal.com/en/downloads-and-information/documents/online-manuals/rsection-1/003845
- Video – Creating RSECTION Cross-Section from DXF File: https://www.dlubal.com/en/support-and-learning/learning/videos/004103
Hedi
