First rod in MembersTable: storage after creation
with API II, I noticed the following bug when creating the MembersTable:
The first member in the table is always assigned a support upon creation, even if this attribute is False.
This behavior occurs exclusively during creation (.create), not during updating (.update).
Of course, I have attached an exemplary model and script to reproduce the issue.
20260604_Bug_Report_SteelJoint_MembersTable.rf6 (1.1 MB)
from dlubal.api import rfem
from dlubal.api.rfem.steel_joints_objects import SteelJoint
def _make_joint(no: int, name: str) -> SteelJoint:
    return SteelJoint(
        no=no,
        user_defined_name_enabled=True,
        name=name,
        nodes=[1],
        members=SteelJoint.MembersTable(
            rows=[
                SteelJoint.MembersRow(
                    no=1,
                    is_active=True,
                    status="Member 1",
                    members_no=[1],
                    end_type=SteelJoint.MembersRow.END_TYPE_MEMBER_ENDED,
                    supported=False,
                    no=2,
                    is_active=True,
                    status="Member 2",
                    members_no=[2],
                    end_type=SteelJoint.MembersRow.END_TYPE_MEMBER_CONTINUOUS,
                    supported=True,
                    no=3,
                    is_active=True,
                    status="Member 3",
                    members_no=[3],
                    supported=False,
        comment="",
        to_design=True,
        all_nodes_to_design=True,
        components={},
        ultimate_configuration=1,
        stiffness_analysis_configuration=0,
def main() -> None:
    joint_1: SteelJoint = _make_joint(no=1, name="Joint without update call")
    joint_2: SteelJoint = _make_joint(no=2, name="Joint with update call")
        rfem_app.create_object_list(objs=[joint_1, joint_2])
        rfem_app.update_object(obj=joint_2)
if __name__ == "__main__":
    main()
Hello Benedikt,
I was able to reproduce the problem and have forwarded it to the development department.
Rebecca Göbel
