Expanding existing dimension chains
I have often noticed in the past that expanding existing dimension chains is relatively very time-consuming and labor-intensive.
While new dimension chains can be created at high speed by defining a key combination, when expanding a dimension chain I first have to click on the existing dimension chain => then click on the Position menu => then scroll down the list, click on Type in the table => select a node => and can now add ONLY ONE SINGLE node at a time using the pointer.
It would be very desirable to either have the possibility to expand dimension chains using a key combination => I click once on the dimension chain to select it => I press ctrl + t => and now I can click on as many nodes/points as I want to include in the dimensioning, analogous to creating a new dimension chain.
Or at least the possibility that in the current workflow => open the Edit Dimension dialog => open the table => you can now directly select multiple nodes in the GUI.
I would be very pleased about a corresponding change in the coming years!
Nick Böttcher
Hi DeflectionPerfection,
thank you for your feedback. There is already as similar request (RUS ID 5155), I have added you as another requester for this feature.
The more requester, the higher the priority :flexed_biceps:
