Export issue with grasshopper
Hi! I have the same problem. I'm working with dlubal RFEM 6.14, rhino 8 and plugin version 8.612.12.1.
Hi omar1234,
welcome to the Community!
I activated the setting for you, can you please try it again?
Dear Stefan,
It works. Thank you very much!
I am experiencing the same issue, but trying to access the client directly from a custom Rhino plugin. I am using the trial version to test the viability on developing an export function to RFEM in my plugin
My user ID is 355011
Hi ,
I am using RFEM 6.14.0007 and I have the same problem as above.
I also get the error in Grasshopper export component: 1. The HTTP request is unauthorized with client authentication scheme 'Anonymous'. The authentication header received from the server was 'Basic realm="example"'.
I have a student license, and first it didn't happen, but suddenly it did.
My licence number 354151
Is it possible to solve the problem?
Best regards JJ
Hi znaibocaj,
first of all, welcomt to the community.
The issue with the authentification should be fixed now, please give it a try. If it doesn't work I need more informations to help you. Your wrote it worked before, with which RFEM version?
Hi znajbocaj,
I checked your settings again, and they're ok. As I asked earlier, could you provide me with more informations?
Please check also Using Dlubal API in Rhino and Grasshopper.
Last but not least, please refrain from posting the same question across multiple channels.
Thank you.
