Master's Thesis: Spring Stiffness of a Leaf Spring
Within the work, a BoF model is to be created. That is, an embedded beam with which the embedding behavior of the connector in the wooden component can be simulated.
I want to model the spring stiffness, i.e., the behavior of the wood, via the diagram input. However, in the input area, there is a field for axial stiffness next to the diagram. If I enter 0 there, since I want to determine my stiffness via the diagram, the program treats the springs as if no stiffness is present. What do I need to do so that the program calculates using the diagram values?
Furthermore, I wonder if the stiffness ux of the spring is defined by the bar direction?
Felix
Hi FelixZ,
thanks for your message!
Bastian Kuhn
Hello @bastian.kuhn,
Thank you very much for the feedback. Here is the file and specifically the section it concerns.
I was under the assumption that the force-displacement relationship I defined in the diagram overrides the axial stiffness in the base window, or that RFEM 6 also uses these values for the axial stiffness when selecting the diagram. However, this does not seem to be the case. My question in this regard is: how do I proceed correctly here so that my stiffness is correctly represented according to the diagram?
Felix
BoF-Modell.rf6 (1.2 MB)
Screenshot 2026-02-19 162716
Screenshot 2026-02-19 162710
Hello FelixZ,
Thank you very much for the file and the images. Currently, you have to enter the unit value 1 for the axial stiffness there. Then you will get the desired deformation.
However, we want to improve this. This process is listed under the internal ID [605360] with us.
Bastian Kuhn
