I am currently working with RFEM 6 and the Form-Finding module to design a membrane tensile structure. The form-finding analysis itself works perfectly, but I am encountering a problem in the next stage of the workflow.
My final goal is to obtain the deformed equilibrium shape of the membrane as a true continuous geometric surface , i.e., a surface that is frozen in its final shape and no longer dependent on the finite element mesh. Ideally, I would like to have this surface directly inside RFEM 6 (for example, to use it as the starting geometry for a new model), although exporting it to a CAD program would also be perfectly acceptable.
As far as I know, the common workaround is to export the final geometry to a CAD program (such as AutoCAD), reconstruct it as a clean surface there, and then import it back into RFEM as a new reference geometry. Unfortunately, I have not been able to make this workflow work either, because every export option I have tried produces only curves or finite element meshes rather than a true surface.
These are the export methods I have tested so far using the standard version of AutoCAD:
- 3D Scene Export to DXF (right-click): Exports only the boundary lines and nodes (wireframe), with no surface information.
- AutoCAD Export (File menu): The export fails silently; no file is opened or generated.
- DXF II Export: This option either does not work or does not produce the expected result.
- Standard DXF Export: Correctly exports the deformed geometry, but represents it as a finite element mesh composed of 3DFACE entities. When I import this file back into RFEM, I obtain a tessellated mesh instead of a single smooth surface.
- IFC Export: This appears to be a possible solution, but it requires AutoCAD Architecture to import and convert the geometry into a solid or surface. I only have the standard version of AutoCAD.
My questions are therefore the following:
Is there an official command, script, or recommended workflow in RFEM 6 to freeze the final form-found shape and convert it into a single mathematical surface within the software itself, independent of the FE mesh?
If not, what is the recommended workflow for exporting a form-found membrane as a true CAD surface (rather than a collection of mesh facets), so that it can later be re-imported into RFEM as clean geometry?
Thank you very much in advance for your time and any suggestions you may have.
