I have already mentioned here that for surface elements, the variable shell thickness using 4 points does not work when the surface is curved.
It turns out that a large part of the functions of RFEM 6 no longer work when the surface is curved, including, for example, the surface eccentricity.
Furthermore, bugs occur when exporting NURBS surfaces from Rhino to RFEM. As a validation example, I tried to reproduce results from the following paper:
https://doi.org/10.1016/j.engstruct.2020.110265
Here, it already fails at the export of the NURBS or Brep. Grasshopper/RFEM gives me the cryptic error:
1. Error to write to web service, for object type: E_OBJECT_TYPE_SURFACE, message: The specified row is outside the allowable range of the nested table.
I get this error for 80% of my surfaces that I want to export…
More development regarding curved structures would be very welcome.
Best regards, Rudi
