Generating result images
I would like to use the new API to generate images. Specifically, I want to select a view and a load case, then display results such as internal forces, deformations, or required reinforcement, and finally export this view as a .png or .jpg file.
I couldn’t find any reference to such functionality in the API documentation. Does anyone know if this is currently possible with the new API? And if not, are there any plans to add this feature in the future?
Hi Martin,
Unfortunately, generating result images directly through the new API is not currently supported in the current version. We recognize that this would be a highly beneficial feature and the request have been forwarded to our development team for consideration.
As soon as there are any updates on this matter, we will inform you accordingly.
The request is logged under already existing RUS ID 4910.
Hi Tomas,
thank you for your response. Due to the highly active development in the API area, RFEM already distinguishes itself from comparable programs in the field of structural engineering. Introducing this functionality would further set RFEM apart from its competitors. I would greatly appreciate it if developments could take place in this area.
Martin
