RSTAB 9: gRPC C# client with VS Community 2022 --> Stand-alone desktop application
For several days I have been trying to create a stand-alone desktop application (C# with VS Community 2022) to communicate with RSTAB 9.
Unfortunately, the application goes into a kind of deadlock after creating an Application object via:
RSTABApp = new ApplicationRSTAB(…);
This is, of course, inside a try-catch-finally block.
If the apiKeyValue is omitted, the application correctly jumps to the exception handling in the catch part.
If the apiKeyValue is used again, a deadlock occurs after the above line and the application no longer responds.
However, RSTAB is correctly blocked:
After that, I tried it with Python:
The script:
from dlubal.api import RSTAB
with RSTAB.Application(api_key_value='ak-…') as RSTAB_app:
# Retrieve the App Info
app_Info = RSTAB_app.get_application_info()
print(f"Version:\n{app_Info.name}")
works perfectly.
Now the same functionality as a C# console application:
using System;
using Dlubal.Api.Common;
using Dlubal.Api.RSTAB;
using Google.Protobuf;
using Google.Protobuf.WellKnownTypes;
using RSTAB = Dlubal.Api.RSTAB;
ApplicationRSTAB? RSTABApp = null;
try
RSTABApp = new ApplicationRSTAB(apiKeyValue: "ak-…");
ApplicationInfo applicationInfo = await RSTABApp.get_application_info();
Console.WriteLine("Version: " + applicationInfo.Name);
if (RSTABApp != null)
Console.WriteLine("Running ...");
else
Console.WriteLine("NOT running!");
catch (Exception ex)
Console.WriteLine($"Error: {ex.Message}");
finally
if (RSTABApp != null) await RSTABApp.close_connection();
Console.WriteLine("\nFinished.");
This also works without problems.
After converting the console application into a desktop application (WinExe) or into a library (DLL) with the same RSTAB API code,
the application goes into a deadlock after
and no further line is executed.
Is this problem known? Can you help me with this?
Thank you very much.
M. Beck, Novum Structures GmbH
Hi mbeck,
We’ve already identified this issue as well. It occurs when asynchronous methods, like CheckConnection(), are used on the UI thread. The root cause stems from the API's handling of multi-threading, especially in environments like WPF.
The goal is to enhance multi-threading support, which will help eliminate deadlocks and ensure a smoother, more reliable experience for users building multi-threaded applications.
I expect the solution to be available within the next a few weeks. I’ll keep you updated as soon as we have more details.
Sorry for any inconvenience this may cause, and thank you for your patience!
Thank you for the quick answer.
Martin
Hello Mr. Pail,
Are there any updates on this?
With the latest RSTAB 9 version 9.13.0001 and the corresponding Dlubal.Api 2.13.1, the stand-alone application unfortunately still does not work.
M. Beck
Hello Mr. Beck,
We are currently testing the C# client without the async approach. Since this is a breaking change, we need to ensure that everything is thoroughly validated. Therefore, this is expected to be included in the next version 2.13.2 or 2.13.3.
Hello Mr. Pail,
With the latest RSTAB 9 version 9.13.0007 and the corresponding Dlubal.Api 2.13.7, the stand-alone application as well as an assembly as a DLL unfortunately still do not work.
The command line version works:
Hello, World!
C:\DEVELOPMENT\Experiments\RS9VSC\bin\Debug\net8.0
Running without SSL
Version: RSTAB 9.13.0007
BASE DATA:
{ "main": { "modelName": "Testfile", "modelDescription": "Test", ... } }
It is running ....
Closed.
Finished.
Code:
using System;
using Dlubal.Api.Rstab;
using Rstab = Dlubal.Api.Rstab;
Console.WriteLine("Hello, World!");
    ApplicationRstab? RstabApp = null;
    Console.WriteLine(Directory.GetCurrentDirectory());
    try
        RstabApp = new ApplicationRstab(apiKeyValue: "ak-...");
        ApplicationInfo applicationInfo = await RstabApp.get_application_info();
        Rstab.BaseData? baseData = await RstabApp.get_base_data();
        Console.WriteLine($"BASE DATA:\n{baseData}");
        if (RstabApp != null)
            Console.WriteLine("It is running ....");
        else
    finally
        if (RstabApp != null) await RstabApp.close_connection();
        Console.WriteLine("\nClosed.");
Is a solution to be expected in the foreseeable future?
M. Beck
Hi mbeck,
we are currently working on release 2.13.8, where the async methods should by changed to sync. Sorry for a delay, since it’s breaking change we want to be sure, everything is working as expected.
Regards
Hi mbeck,
starting with RSTAB 9.13.0008 and C# client packages 2.13.8, the C# client connection handling was changed from async to sync, which removes the UI-thread deadlock. Please update to 9.13.0008 | 2.13.8 (or newer) and try again.
Looking forward for the feedback.
Regards
Hello Mr. Pail,
yes, that works now :+1:
I will write any further questions/problems in a separate thread.
M. Beck
