Import an Excel file into the terrain tab
Hello everyone.
I am currently trying to import an .xls file that contains point coordinates into RFEM 6 via the Terrain | Table tab that can be found on the Base Data .
What do I need to do to the file in order to import it?
Pedro
Hi PedroSoares,
Thanks for your message! :slightly_smiling_face:
Unfortunately, I’ve just noticed that the import function can’t detect the active worksheet at the moment. We’ll take a closer look at this together with our development team and analyze what’s going on. :magnifying_glass_tilted_left:
As a workaround, you can still proceed without any issues:
  • Copy your values directly from Excel
  • Paste them manually into the Terrain table using Ctrl + V
This should allow you to continue working smoothly in the meantime. :flexed_biceps:
Hello Stefan.
Thank you for the tip. I hope the function will be working soon.
Pedro
