Problem importing a custom accelerogram from Excel into RSTAB
I am trying to import a custom accelerogram from an Excel file into RSTAB 9.13.0001, but unfortunately without success.
I have created an Excel table with real time-acceleration values (time t and acceleration a_x​). However, when importing via the function
"Import table data from spreadsheet"
the following error message appears:
"The worksheet '' was not found."
The file is saved as *.xlsx.
The worksheet is named "Zeiten & Beschleunigungen" (Times & Accelerations).
The structure corresponds to the template exported by RSTAB (columns: No., Time, ax, ay, az).
For verification, I manually entered the first five values directly in RSTAB and then generated an Excel file using the export function. Even this file generated by RSTAB cannot be successfully imported again.
I would appreciate any hints, as I need the accelerogram for my master's thesis.
Gleb
Hi GleBooBIM,
I have already initiated an improvement to the program. In the meantime, the accelerogram can be pasted into the RSTAB table from Excel via Copy & Paste (Ctrl+C / Ctrl+V) (see video).
Sonja von Bloh
Hello Sonja!
Thank you very much for your support and the quick feedback.
The import of the accelerogram actually worked exactly in the way you described and showed – by copy & paste (Ctrl+C / Ctrl+V) directly from Excel into the RSTAB table. This allowed me to easily transfer and further process the data.
Thank you very much for that!
Gleb
