IFC file import in RFEM 6
importing an ifc file from Archicad of a civil building on piles, when selecting the piles RFEM crashes the entire PC, I repeat RFEM does not close but the computer shuts down, can someone help me? thank you
Hi Vincenzo,
welcome to the Dlubal Community :waving_hand: Good, to have you here :smiley:
Have you installed the latest graphics card driver on your PC?
If no, please update it and try again.
If you your graphics card driver is up-to-date and you're still facing the issue, please share the IFC file here so we can analyse the problem more precisely.
:owl: Prefer not to share the file publicly? No problem – send it to me via direct message: click on my profile picture or user name → Message.
Clemens Gutmann
"Hi Clemens,
Thanks for your reply. To be more precise, the issue is quite critical: when I import the IFC file from Archicad and try to select the piles, RFEM doesn't just crash, but my entire PC completely shuts down.
I have already checked and verified that my graphics card drivers are fully up-to-date, but the problem persists. Since the IFC file contains professional project data, I prefer not to share it publicly. However, I cannot see the 'Message' button on your profile. Could you please send me a direct message first, so I can reply to it and safely attach the file?
Thank you for your help!"
Hi Vincenzo,
Please check again; it should work now.
Cheers
I have updated the Nvidia video drivers and I am testing; I’m not completely sure but maybe with these new drivers I might have solved it, thanks for your availability.
Vincenzo
