Incorrect Topology of Surface Contact
Hi all,
Newbie here. I’ve noticed that the surface contacts stop working with small changes in the overall geometry. These changes aren’t even made on the surfaces in question. Mesh generation does not complete and returns error message, “Incorrect Topology of Surface Contact”. My workaround is forcing mesh refinements on these surfaces to replicate the same meshing. If that doesn’t work, I remodel the entire thing. I’ve experienced this issue whenever the model is a bit complex. Has anyone faced this problem before?
Thanks,
SG
Hi SOHANGEORGE,
thanks for your message.
First, please make sure that you are using the current customer version. The issue may already have been identified and resolved.
You can download the current customer version here:
https://www.dlubal.com/en/support-and-learning/learning/videos/003398
If this does not solve the problem:
:right_arrow: Click on File → Save as and choose the following settings to reduce the file size:
:owl: Prefer not to share the file publicly? No problem – send it to me via direct message: click on my profile picture or user name → Message.
Marco Nikoleizig
