Unstable model in calculation
I am trying to design a steel container, but my model is unstable. Can you tell me what might be causing this?
Darek
Hi Darek,
Thank you very much for your question.
Instabilities can have various causes. In the following FAQ, we have listed the most common causes. Have a look to see if any of the points are helpful for you:
Finding and fixing instabilities in calculations: cause analysis and solutions
Clemens Gutmann
Hello Clemens,
it was a numerical problem. Due to the shortening of the supports, the bracing failed, so I assigned a minimal compressive force to the tension members. After that, the calculation ran through :)
Thanks for the link to your FAQ... that helped me a lot.
