Mesh refinement at singularities
I have a question about node mesh refinement. I am currently experimenting with surface structures and singularities. In a script, I found a figure where the mesh refinement at the node was chosen so that the resulting section only shows the stresses at the support edge. (see image)
I have been playing around with the node mesh refinement but cannot achieve the same result. The file is attached:
Kap.4.11_3DPlattensystem_Vorlage_01.12.2025.rf6 (5.1 MB)
Could you tell me where the difference lies and how I can achieve similar results in the section? I find it quite an elegant solution.
Best regards and many thanks,
Lennart
Hello Lennart,
you can achieve this internal force distribution with a cutout of the support area by defining the node support as "stiffness via fictitious support":
Rebecca Göbel
That's exactly it! Thank you very much, Rebecca :)
