RFEM 6 - Control Load Assistants via API
Is it already possible to control the load wizards for wind and snow using the RFEM 6 API? I want to apply the loads for a hall system via the load wizards using the API (C#).
I have already found a command called "load_wizard" in the current API references but have difficulty defining it correctly, if possible.
Maybe someone here can help me and has already used this command.
Hello Marrcel,
welcome to the Dlubal Community! :tada:
Unfortunately, the load assistants for wind and snow cannot yet be controlled via the API at the moment. However, a corresponding function is already in planning.
I will keep you updated here :slight_smile:.
Rebecca Göbel
Hello Rebecca,
Thank you very much for the quick response.
Is it worth waiting for the functions of the load assistants via the API since they will be implemented soon, or could this still take a bit longer? :)
Marcel
