Long wait times for resultant views on line releases
Hi guys, nice to be here!
The problem is that RFEM regenerates the graphic of resultant view each time the user performs an action... and it takes forever.
For example, I display the Max-values for Resultant on line releases (I wait 20 min for the program to generate the view), then I want to display the Min-values (I wait 20 min to generate the view again), then I want to go back to the Max-values (the program regenerates the view also 20 min, even though it has already generated it once).
Is there any way to configure this so that previously generated graphical results are always quickly available in RFEM?
This is not the problem with harware for sure, because of:
CPU: Intel i9-11950H 2.60-5.00 GHz
RAM: 128GB SODIM 3200MHz
SSD: Samsung PM9A1 MZVL21T0HCLR
GPU: NVIDIA RTX A3000
Any ideas?
Hi DamianW,
Just a quick note: RFEM does not store already displayed results in the cache.
Based on the information provided so far, I'm unfortunately unable to resolve your issue.
:wrench: To investigate further, please send us your model file without results.
This will help us support you more effectively! :blush:
Thanks in advance!
