In RFEM 6.12.0010, the arrows on members showing their orientation are not visible, even though it checkbox is checked, as seen in the video.
Hi there! ![]()
Have you tried restarting RFEM? Does the issue also occur in other/new files?
- If not, could you please send me the file in question?
- If yes, I believe it might be related to a graphics issue. In that case, please try updating your graphics card driver to the latest version.
Let me know how it goes! ![]()
Thank you for your reply.
I found that the existence of a background layer dxf is causing the problem, as shown in the video.
more specifically, the length unit of the dxf file is affecting the visibility of the member orientation arrows:
background layer of dxf file with length unit in mm => no problem
background layer of dxf file with length unit in m => member orientation arrows disappear
deleting the background layer of dxf file with lengths in m => arrows come back
Thank you for your feedback and good that you found the reason. Could you please provide your files to double-check it. Thank you.
