Deactivate minimum longitudinal reinforcement diameter 9.5.2(1) without affecting other K-rules of longitudinal bars
In a slab beam/beam girder in my model, which was modeled as a rib bar, it is designed as a column due to its normal forces, which means that the corresponding construction rules apply in these areas.
However, since I want to deliberately deactivate this and conservatively reinforce it as a beam, I want to disable this.
I find it difficult to selectively deactivate the verification according to 9.5.2, since I generally want to continue using the advantages of checking the construction rules for longitudinal bars, just not those for columns. How can I specifically deactivate the verification of the minimum longitudinal reinforcement diameter without generally deactivating the construction rules/minimum reinforcement of the longitudinal bars?
Hi DeflectionPerfection,
Hello and thank you for your question! :waving_hand:
Currently, it is not possible to selectively deactivate individual structural verifications. In the global settings, you can only:
  • deactivate all structural verifications
    or
  • deactivate none (i.e., keep all active)
You can find more information in our online manual at the following link:
:backhand_index_pointing_right: Global Settings – Concrete Design
I hope this helps you! If you have any further questions, we are of course happy to assist you. :blush:
