Modeling restriction in RFEM 5
I can't use non linear material property for my rib beam and when I want to model a rib beam in a slab that has non linear material property. Rfem5 will send an error message. Can someone help me out
Hi Chukwudalu,
:warning: Avoid Using Rib Member in This Context. It's recommended not to use rib member in this case.
You can find detailed instructions in the following FAQ: Design of Ribbed Plate in Cracked State with RF-CONCRETE NL and Export of Stiffnesses
Feel free to reach out if you have any further questions! :blush:
