I am trying to model a embedded beam in RFEM 6 as part of my studies, but I am not fully satisfied with the result.
The beam should be modeled in 2-D and initially be rigid. The model itself is supposed to represent a pressure plate on a wooden beam with screw reinforcement. Here, the wooden beam and the screws should be symbolized by springs. The beam is loaded with a line load. For illustration, I have attached a hand sketch of the model. The dimensions and the magnitude of the load are secondary for now, as it is about the principle.
The model only allows me to apply a rod support without causing error messages. Shouldn't I actually be able to apply a line support for the wood and a node support for the screws, and the beam would still be supported? However, when I try this, I get the warning “Line support cannot be assigned to line no. 1, which is not connected to any surface.”
The wood and the screws should also exhibit tri- or bilinear behavior, which I believe I can select in the line supports by choosing “Diagram” under “Nonlinearity” and then reflecting the curve based on displacement and force. If I am wrong, please correct me.
I do not have this option with the rod support, as it only offers the choice of “failure,” and I also do not want to influence the “nonlinearity” of the rod, since it is about the wood and the screws as springs.
So, to represent my model and be able to read out the resulting forces in the springs, I have to work with line supports and not with the rod support, right? Or is there another possibility?
I would be very happy if you could help me with my problem and, ideally, provide a model as described for illustration so that I can better understand where my mistake lies.
Thank you very much in advance.
