Modelling steel sections inside concrete sections
Hello everyone.
I´m trying to model a thin-walled C section that will be placed inside a concrete section (see image bellow), but I cant find a way to do it.
When I try to calculate the section using RSECTION, it says the sections are overlaping and stops the calculation.
Is it possible to model this section? If it is, how do I do it?
Hi PedroSoares,
Yes, such cross-sections can be modeled in RSECTION. :blush:
Please first follow these steps:
  1. Activate Finite Element Analysis
    Make sure that Finite Element Analysis is selected in the Basic Data.
  2. Avoid Overlapping
    Ensure that the steel profile does not overlap the concrete cross-section. To guarantee this, you need to create an opening in the concrete cross-section.
    The boundary lines of this opening correspond to the boundary lines of the steel cross-section.
If the error message still appears afterward, please send us your model so that we can take a closer look. :face_with_monocle:
Additional Note:
Recently, there is a new cross-section category in RFEM 6. Your exact cross-section is not yet included, but it might be worth taking a look. :magnifying_glass_tilted_left:
Niklas Wanke
Hello @niklas.wanke .
First, I want to thank you for the help and information you already gave.
Now, I´ve tried to apply the method you explained, but I still can´t calculate the section.
I will send you the model for evaluation.
Solução_betão_c200_3.rsc (1.0 MB)
Could you explain what I´ve done wrong?
Pedro
I took a closer look at your model. To perform the cross-section calculation, you still need to decompose the concrete cross-section. Only then will the opening be effective.
Attached you will find the adjusted model. Please review the changes and let me know if there are any further questions. :+1:
Solução_betão_c200_3_mod_Dlubal.rsc (856.0 KB)
Niklas Wanke
