I am currently verifying the proof at mid-span in a type of beam known as a beam bar within a beam/plate girder:
Construction rules | Offset dimension for longitudinal tension reinforcement according to 9.2.1.3(2) not satisfied.
Unfortunately, I do not quite understand what exactly is being verified here, since when I think of the offset dimension, I consider the horizontal spacing in the cross-section of two longitudinal bars in a lap splice/anchorage, but at this location in mid-span, such a splice does not exist.
I would greatly appreciate any feedback or help regarding the proof being conducted:
Hi DeflectionPerfection,
Thank you for your message!
Click on File → Save As and choose the following settings to reduce the file size:
Then upload the file here (e.g., *.rf6, *.rs9) – this way the community can also contribute to the solution.
Don’t want to share the file publicly? No problem – send it to me via direct message: click on my profile picture or my username → Message.
In the case of overstress of the cross-section (i.e., when UL 0100 > 1), a calculation of the steel stresses is no longer possible. However, these stresses are the basis for the structural verification DM 0205.
Therefore, in this case, only the utilization is displayed with reference to UL 0100.
As soon as UL 0100 is complied with (≤ 1.0),
the verification DM 0205 can be correctly performed and the corresponding verification format can be displayed.
If you have any further questions or need support, feel free to contact me anytime!
