Mesh refinement and contact modeling for foundation
I have modeled a foundation (8m x 7m x 0.2m) and a solid soil mass (56m x 49m x 16m; 1m gravel layer, with sand below). The two solid bodies are connected by a surface contact (failure in tension, rigid friction).
I refined the mesh around the slab using a node mesh refinement and by subdividing the soil. Is there a more elegant way to do this?
The actual problem is that the load cases and load combinations do not converge. The convergence diagram shows a displacement that, after a certain point, no longer changes as the number of iterations increases. Nevertheless, the iterations continue until the maximum number of iterations set is reached. It works when the surface contact is set to full force transmission. What can I do?
Thank you!
Hello Emily,
The model file would be very helpful for analyzing the problem in more detail:
:right_arrow: Click File → Save As and select the following settings to reduce the file size:
:right_arrow: Then upload the file here (e.g. *.rf6, *.rs9) — that way, the community can also help find a solution.
:owl: Don't want to share the file publicly? No problem — send it to me in a direct message: click my profile picture or username → Message.
Juliane Stopper
