NodalLoad Force Eccentricity
I'm trying to set force eccentricity on nodal loads via API II (Python/gRPC).
The API docs don't list it: https://apidocs.dlubal.com/source/rst_objects/rfem/loads/nodal_load.html
But looking at nodal_load_pb2.pyi in the dlubal package, the fields exist:
force_eccentricity: _common_pb2.Vector3d
force_eccentricity_x: float
force_eccentricity_y: float
force_eccentricity_z: float
I tried setting it like this:
rfem.loads.NodalLoad(
    no=1,
    load_case=10,
    nodes=[5],
    load_type=rfem.loads.NodalLoad.LOAD_TYPE_FORCE,
    coordinate_system=3,
    load_direction=rfem.loads.NodalLoad.LOAD_DIRECTION_GLOBAL_X_OR_USER_DEFINED_U_TRUE_LENGTH,
    force_magnitude=50000.0,
    force_eccentricity_z=0.35,
No errors, but when I check the model in RFEM the "Force Eccentricity" checkbox isn't ticked and the value isn't there.
I notice there's no has_force_eccentricity boolean like there is has_specific_direction for specific direction. Is there a flag I'm missing, or is this field not writable yet (ie not implemented in the api yet)?
Thanks
Hi Samuel,
I tested it and where able to reproduce the issue. However since it is not shown in the documentation I wouldn't expect that it is implemented at all. I wrote a bug report (Bug ID = 586883) and passed it to the dev team. Once it has been properly implemented, we will announce it in the release notes.
Have a nice evening.
Hi Samuel,
It looks like the issue you're experiencing with setting the force eccentricity for nodal loads via API II has been addressed in the 6.14.0005/2.14.5 release. This update includes the addition of the force_eccentricity_enabled attribute to the NodalLoad object to allow using such feature.
Please let us know if everything works as expected now. Your feedback is greatly appreciated!
Hi Tomas,
Thanks for letting me know! I went back to my old script and tested it and it works perfectly on 6.14.0006.
Cheers,
Samuel
