Parametric flat bar creation lacking properties
as shown in the video, using API2.12.13 and RFEM6.12.0013, I create a member with a parametric cross-section FLAT 440/80/H, but the cross-sectional properties are missing and the cross-section is not valid.
IMessage message = new RFEMApi2.StructureCore.CrossSection()
No = cs.Number,
Name = cs.Name,
Material = cs.Number_material,
I then type in the same string for the name of the cross-section, and the GUI assigns the cross-sectional properties.
How can I trigger the assigning of the cross-sectional properties, when creating members using API2?
Hi PSA001,
you can create your modell in RFEM, and then export the Python code.
File => Export => Phython Script | Dlubal API | gRPC
Open the file in your IDE, and you can see how it should be used. If it doesn't work please send me an RFEM example and I'll have a deeper look.
Hello PSA001,
To trigger the cross-sectional properties correctly when creating the member, here's the right code snippet:
var objectsToCreate = new List<Google.Protobuf.IMessage>
    new Rfem.StructureCore.Material
        No = 1,
        Name = "S355"
    new Rfem.StructureCore.CrossSection
        No = 1,
        Material = 1,
        Type = Rfem.StructureCore.CrossSection.Types.Type.ParametricBars,
        Name = "FLAT 0.440/0.080/H"
await rfemApp.create_object_list(objectsToCreate);
Let us know if this helps!
