I have a project with I-beams from STEICO (STEICOjoist) and I would like to be able to size them according to the criteria of my building (deflection limits, number of supports, etc.) but I'm not quite sure how to go about it. Is there a simple way to do this, or any documentation on how to do it?
Massimo
The stiffness and strength values can be found in tabular form in the respective ETA.
You can define the stiffnesses using the member type “Definable Stiffness” in RFEM. This allows you to directly assign custom stiffness properties to the element.
Further information about this member type can be found here:
https://www.dlubal.com/en/downloads-and-information/documents/online-manuals/rfem-6/006106#h-17
For the design, you can use our Components add-on. To do so, the required data first needs to be properly entered and assigned within the model.
More information about the workflow and setup can be found here
https://www.dlubal.com/en/support-and-learning/learning/webinars/003780)
