I am currently trying to model a beam structure using the Excel Add-In as the interface between Excel and RFEM 6.
For this, I create a beam model (truss structure) and transfer the cross-sections as a table with number, name, material, as well as the cross-sectional properties (A, A_y, A_z, I_T, I_y, I_z) and the dimensions width and height. Nodes, lines, and beams are correctly read in via the same method, but the cross-sections are not.
When importing these cross-sections from Excel into RFEM 6, the transferred cross-sectional values are not fully adopted. Instead of the defined cross-section (intended as the base cross-section), RFEM creates a standard rectangle 500/1000mm.
The effect occurs regardless of the content of the value columns. Even if I export a previously defined cross-section from RFEM itself to Excel and then import the unchanged table directly again, the standard rectangle 500/1000 appears upon re-import, not the original cross-section. The number and name columns are received, but the geometric definition of the cross-section is not.
Questions:
Is there a documented format or example table for cross-section import that I can refer to?
If creating a base cross-section via this method is not possible, what alternatives are there? Ideally also without using the API.
Did you change the names of the cross-sections in Excel afterward? A cross-section named "HT - Hauptträger im Endfeldbereich" cannot be a valid cross-section name in RFEM, which results in a "500/1000 placeholder cross-section" being generated.
I was able to export validly defined cross-sections and re-import them without any issues.
First of all, thank you for the prompt response
I was also able to enter the names in RFEM as you suggested. However, I had already thought that the designation might not fit and that the cross-section must start with "Basis". But that didn't work either.
As they are entered in the screenshot, RFEM recognizes the cross-sections and calculates with the corresponding cross-section values, both with the "Basis" designation and with the custom designation. Unfortunately, the cross-sections required for my model are not standard cross-sections, so I have to create an individual cross-section based on the Basis cross-section.
Thanks for clarifying. RFEM recognizes the basic cross-sections and can use them to calculate the structural analysis.
Unfortunately, they can’t be read during import.
What kind of cross-sections do you need for your model? Perhaps they can be represented using cross-sections from the library.
