RFEM MCP server connection on a different port
I am trying to run MCP server on my system. However, I am running into issues with regards to port.
The RFEM grpc server runs by default on 9000 port, however, in my system, this port is occupied by a critical security process (which cannot be moved or turned off due to company policies). Therefore, in my system the RFEM grpc runs on 9001.
Now as I understand the RFEM MCP server is so built that it tries to reach the RFEM grpc server at port 9000 by default. That is the reason I am not able to execute my prompt's successfully. I have extensively tried to shift the port where RFEM's MCP server tries to connect to RFEM grpc server by modifying config files in RFEM_mcp_server and dlubal api, however, no luck.
I am following the same instructions as given herein on the website: MCP Server — Dlubal API documentation.
After extensive research everything looks fine and this is the last step which is proving to be a hurdle. I would appreciate if someone can be of help here.
I am also trying to communicate with our IT-team to look into changing the port of the security process. But chances are highly unlikely that they would make an exception for one. Hence, I dropped in to check here.
Curious to hear about solutions.
Kind Regards,
Nitesh
Hello @mnitesh27 ,
it is currently not possible to change the port that the MCP server connects with. It has to be port 9000. We already forwarded this wish to our development department.
Rebecca Göbel
Hi Rebecca,
Thank you for your response. Your colleague did indeed inform me about it but it felt a bit unclear. Therefore, I decided to ask it in here.
Is there a timeline on when this could be implemented?
Kind Regards,
Nitesh
Hi Nitesh,
It is not yet possible to reliably define a specific timeframe but I can keep you updated here.
Best Regards,
Rebecca Göbel
